跳转到主内容
加入维修社区 - 创建账户
Samsung Gear Fit Battery Replacement
你所需要的
    1. Samsung Gear Fit Battery Replacement, Watch Band: 步骤 1 中的图像 1,2 Samsung Gear Fit Battery Replacement, Watch Band: 步骤 1 中的图像 2,2
      • Place your thumbs on the ends of the screen.
      • Push the watch outward while pulling the band away from the watch.
      询问修复机器人
      添加评论
    1. Samsung Gear Fit Battery Replacement, Screen: 步骤 2 中的图像 1,1
      • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
      • For step-by-step instructions on using an iOpener, see the iOpener 指南.
      • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
      询问修复机器人
      添加评论
    2. Samsung Gear Fit Battery Replacement: 步骤 3 中的图像 1,3 Samsung Gear Fit Battery Replacement: 步骤 3 中的图像 2,3 Samsung Gear Fit Battery Replacement: 步骤 3 中的图像 3,3
      • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
      • Gently pry the screen loose using a plastic opening tool.
      • If the screen doesn't easily come loose, more heating may be required
      询问修复机器人
      添加评论
    3. Samsung Gear Fit Battery Replacement: 步骤 4 中的图像 1,3 Samsung Gear Fit Battery Replacement: 步骤 4 中的图像 2,3 Samsung Gear Fit Battery Replacement: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      • Using tweezers as a lever, pry the inner assembly out of the external casing.
      • This will be harder than removing the screen. Moderate force may be required.
      询问修复机器人
      添加评论
    4. Samsung Gear Fit Battery Replacement: 步骤 5 中的图像 1,3 Samsung Gear Fit Battery Replacement: 步骤 5 中的图像 2,3 Samsung Gear Fit Battery Replacement: 步骤 5 中的图像 3,3
      • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
      询问修复机器人
      添加评论
    5. Samsung Gear Fit Battery Replacement: 步骤 6 中的图像 1,2 Samsung Gear Fit Battery Replacement: 步骤 6 中的图像 2,2
      • Gently peel the screen assembly up and away from the device using tweezers.
      添加评论
    1. Samsung Gear Fit Battery Replacement, Motherboard: 步骤 7 中的图像 1,3 Samsung Gear Fit Battery Replacement, Motherboard: 步骤 7 中的图像 2,3 Samsung Gear Fit Battery Replacement, Motherboard: 步骤 7 中的图像 3,3
      在这个步骤中使用的工具:
      • Three ribbon cables hold the motherboard to the rest of the assembly.
      • The battery cable in the front.
      • When reassembling the device, make sure the battery cable is securely connected. Moderate force may be required to push it in all the way.
      • And two on the side.
      • Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
      询问修复机器人
      添加评论
    2. Samsung Gear Fit Battery Replacement: 步骤 8 中的图像 1,2 Samsung Gear Fit Battery Replacement: 步骤 8 中的图像 2,2
      • The motherboard is a segmented three piece construction.
      • Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
      • Be sure to use ESD safe tweezers to prevent static discharge from zapping your device.
      询问修复机器人
      添加评论
    3. Samsung Gear Fit Battery Replacement: 步骤 9 中的图像 1,1
      • The motherboard should now be removable from the assembly.
      • Use tweezers to lightly pry, lift, and remove the board by its middle section.
      • If the motherboard is stuck it may be caught on the assembly. Wiggle it around to free it. You may also need to pull the edges of the assembly away from the motherboard to create space.
      询问修复机器人
      添加评论
    1. Samsung Gear Fit Battery Replacement, Battery: 步骤 10 中的图像 1,2 Samsung Gear Fit Battery Replacement, Battery: 步骤 10 中的图像 2,2
      • With the motherboard removed, the battery is exposed.
      • A small metal strut protects the battery.
      • Remove the small metal strut by prying it out of both sides of the enclosure.
      添加评论
    2. Samsung Gear Fit Battery Replacement: 步骤 11 中的图像 1,3 Samsung Gear Fit Battery Replacement: 步骤 11 中的图像 2,3 Samsung Gear Fit Battery Replacement: 步骤 11 中的图像 3,3
      • Use caution when handling the battery. If damaged or punctured, it can release hazardous chemicals or catch fire.
      • Remove the battery by pulling on the pull tab.
      • Don't be afraid to use force, the battery is tightly packed into the plastic enclosure.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. Make sure that the ribbon cable connecting the battery is firmly attached; Don't be afraid to use some force.
取消:我没有完成这个指南。
37等其他人完成本指南。
Nathan Powell
于04/24/14注册
1,584 声望
创作了3篇指南
团队
Cal Poly, Team 11-49, Amido Spring 2014 Cal Poly, Team 11-49, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G49
4 名成员
创作了12篇指南
10指南评论
Bgdhdhdhxhzjxjchf
engineer taha - 回复 分享
Gdkysgkdgkdgxgmzg
Anyone know where I can find replacement parts for the charging terminals? One of the 5 fell out and I can't seem to find this simple piece anywhere.
Alexis Sanchez - 回复 分享
Where can I purchase a replacement battery?
Soloze - 回复 分享
Where i can purchase a replacement battery in india?
Somak Guchhait - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 16
过去 30 天: 81
总计 74,930
