跳转到主内容
Samsung Gear 2 Speaker Replacement
你所需要的
  1. Samsung Gear 2 Speaker Replacement, Front half and Back half: 步骤 1 中的图像 1,2 Samsung Gear 2 Speaker Replacement, Front half and Back half: 步骤 1 中的图像 2,2
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Speaker Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Speaker Replacement: 步骤 3 中的图像 1,3 Samsung Gear 2 Speaker Replacement: 步骤 3 中的图像 2,3 Samsung Gear 2 Speaker Replacement: 步骤 3 中的图像 3,3
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Speaker Replacement, Battery: 步骤 4 中的图像 1,2 Samsung Gear 2 Speaker Replacement, Battery: 步骤 4 中的图像 2,2
    • Use the pointed side of the spudger to remove the small, orange battery cable.
    I just broke the Orange battery cable. DAM!!!!! WHAT DO I SUGGEST
    Robert Valdez - 回复
    How did you do that?
    Wes robbins - 回复
  5. Samsung Gear 2 Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Gear 2 Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the battery by pulling the white tab on the battery marked "PULL."
    • Make sure the orange battery cable is fully disconnected to avoid ripping it off and tearing it.
    I just broke the Orange battery cable what next
    Robert Valdez - 回复
  6. Samsung Gear 2 Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 Samsung Gear 2 Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Using tweezers, lift the rectangular speaker from the case.
    • Be careful to not pull too quickly and rip the orange connector cable, which is attached to the case with adhesive.
  7. Samsung Gear 2 Speaker Replacement: 步骤 7 中的图像 1,2 Samsung Gear 2 Speaker Replacement: 步骤 7 中的图像 2,2
    • Use tweezers to carefully grab the connector.
    • Gently pull upwards to detach it from the case and from the adhesive.
    where can the speaker be purchased?
    dan13av - 回复
结论
4等其他人完成本指南。
Devin Mast
于04/14/14注册
637 声望
撰写一个指南
团队
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 的会员
CPSU-MANESS-S14S13G27
4 名成员
创作了6篇指南
3条评论
what happens if I don't put the speakers back?
alejandrayin5 - 回复
If you don't what the gear to make the sound when using camera or video take the speaker out. It works fine its just a speaker. I did that with my gear 2 that I bought march 2015.
Edna - 回复
Where can I buy the speaker?
Bob Wagenvoort - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 4,154
