跳转到主内容
Samsung Galaxy Y Charging port and headphone jack Replacement
你所需要的
  1. Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 步骤 1 中的图像 1,3 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 步骤 1 中的图像 2,3 Samsung Galaxy Y Charging port and headphone jack Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Use the blue plastic opening tool to pry the back-panel off of the device.
  2. Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 步骤 2 中的图像 1,3 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 步骤 2 中的图像 2,3 Samsung Galaxy Y Charging port and headphone jack Replacement, Charging port and headphone jack: 步骤 2 中的图像 3,3
    • Use the screwdriver with a PH000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
    • Remove the SD card as well by sliding the card out of it's slot.
  3. Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 3 中的图像 3,3
    • Use metal pry tool to separate the interior back panel from the interior hardware and screen.
  4. Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 4 中的图像 3,3
    • Disconnect the orange motherboard connection, then remove interior hardware from the front screen display.
  5. Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the five 2mm screws located in the corner of the silver protective panel.
    • If the motherboard is cracked or damaged, then replace with a new one.
  6. Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Y Charging port and headphone jack Replacement: 步骤 6 中的图像 3,3
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 652
