简介
If you are a constant headphone user, the jack on your Galaxy Tab S3 can get worn out over time. If you have already tried cleaning the debris out of the headphone jack with a toothpick and it still doesn't work, you may need to replace the jack. This guide will show you how to properly remove and replace the headphone jack module.
你所需要的
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Insert the pointy end of the spudger into the headphone jack.
Lift the spudger up to snap the headphone jack module off of the motherboard.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
另外一个人完成了本指南。
