跳转到主内容
Samsung Galaxy Tab S3 Front Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Display: 步骤 1 中的图像 1,1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
    There is no reason to remove the screen while replacing a battery.
    Nick Youngstrom - 回复
    Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
    Phenix City - 回复
  2. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
    Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
    Jacques Barreau - 回复
  3. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
    For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
    Moisés Jover - 回复
  4. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: 步骤 5 中的图像 1,2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Rear glass panel: 步骤 5 中的图像 2,2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: 步骤 6 中的图像 1,2 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Battery: 步骤 6 中的图像 2,2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 7 中的图像 1,1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 8 中的图像 3,3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 9 中的图像 2,2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 10 中的图像 2,2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 11 中的图像 1,1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: 步骤 12 中的图像 1,3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: 步骤 12 中的图像 2,3 Samsung Galaxy Tab S3 Front Facing Camera Replacement, Front Facing Camera: 步骤 12 中的图像 3,3
    • Using a nylon spudger, carefully push the camera out of its framing.
    • Unlike the rear facing camera, you will be pushing this camera out from the front. Try to push on the side of the camera so as to not damage the lens with the pointy end of the spudger.
  13. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 13 中的图像 1,2 Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 13 中的图像 2,2
    • Carefully pop the front facing camera off from the motherboard with the flat end of the spudger.
  14. Samsung Galaxy Tab S3 Front Facing Camera Replacement: 步骤 14 中的图像 1,1
    • Remove the front facing camera from the device.
结论
另外一个人完成了本指南。
Justin Ogihara
于09/18/17注册
27,209 声望
创作了52篇指南
团队
EDU Team EDU Team 的会员
Staff
7 名成员
创作了637篇指南
一条评论
This repair can be done without removing the screen!
hansderaedt - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 13
总计 371
