跳转到主内容
Samsung Galaxy Tab S3 Daughterboard Replacement
你所需要的
  1. Samsung Galaxy Tab S3 Daughterboard Replacement, Display: 步骤 1 中的图像 1,1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 2 中的图像 1,1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 4 中的图像 3,3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Daughterboard Replacement, Rear glass panel: 步骤 5 中的图像 1,2 Samsung Galaxy Tab S3 Daughterboard Replacement, Rear glass panel: 步骤 5 中的图像 2,2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Daughterboard Replacement, Battery: 步骤 6 中的图像 1,2 Samsung Galaxy Tab S3 Daughterboard Replacement, Battery: 步骤 6 中的图像 2,2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 7 中的图像 1,1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 8 中的图像 3,3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 9 中的图像 2,2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 10 中的图像 2,2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 11 中的图像 1,1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 1,3 Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 2,3 Samsung Galaxy Tab S3 Daughterboard Replacement, Daughterboard: 步骤 12 中的图像 3,3
    • Use a spudger to pry up four press fit connectors from the lower board containing the charging port.
  13. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 13 中的图像 3,3
    • Pry up the two coaxial cables joining the daughterboard to the motherboard.
    • Be sure to pull the white coaxial cable from the small bracket holding the wire to the daughterboard before removal.
  14. Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 14 中的图像 1,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 14 中的图像 2,3 Samsung Galaxy Tab S3 Daughterboard Replacement: 步骤 14 中的图像 3,3
    • Pry the daughterboard up from the midframe with a spudger.
    • Remove the daughterboard.
结论
3等其他人完成本指南。
Austin Blakely
于03/11/19注册
21,557 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
120 名成员
创作了20,835篇指南
3指南评论
Do you need to remove the front display assembly to replace the daughterboard? From the images it appears you just have to go in through the back glass to do this job. Confused.
Grant Ormsby - 回复
You do, because the midframe is adhered to both the front and back. It won't come off if you just take off the back.
Flint Green -
You don't have to take screen off. Just disconnect battery.
Jake Fowler - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 18
总计 2,434
