跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab S3 Battery Replacement
你所需要的
    1. Samsung Galaxy Tab S3  Battery Replacement, Display: 步骤 1 中的图像 1,1
      • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
      • Leave the iOpener on edge for two minutes.
      • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
      添加评论
    2. Samsung Galaxy Tab S3  Battery Replacement: 步骤 2 中的图像 1,1
      • Place a suction cup near edge that you heated up with the iOpener.
      • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
      • Use an opening tool to split apart the glass panel from the midframe.
      • Be careful to not break the glass when prying from the frame.
      添加评论
    3. Samsung Galaxy Tab S3  Battery Replacement: 步骤 3 中的图像 1,1
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
      • You can also use multiple opening picks instead of a plastic card.
      添加评论
    4. Samsung Galaxy Tab S3  Battery Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy Tab S3  Battery Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy Tab S3  Battery Replacement: 步骤 4 中的图像 3,3
      • Pull off the glass panel using the suction cup.
      • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
      • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
      询问修复机器人
      添加评论
    5. Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: 步骤 5 中的图像 1,2 Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: 步骤 5 中的图像 2,2
      • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
      询问修复机器人
      添加评论
    1. Samsung Galaxy Tab S3  Battery Replacement, Battery: 步骤 6 中的图像 1,2 Samsung Galaxy Tab S3  Battery Replacement, Battery: 步骤 6 中的图像 2,2
      • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
      询问修复机器人
      添加评论
    2. Samsung Galaxy Tab S3  Battery Replacement: 步骤 7 中的图像 1,1
      • The midframe should snap off from the device’s motherboard.
      询问修复机器人
      添加评论
    3. Samsung Galaxy Tab S3  Battery Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab S3  Battery Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab S3  Battery Replacement: 步骤 8 中的图像 3,3
      • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
      询问修复机器人
      添加评论
    4. Samsung Galaxy Tab S3  Battery Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab S3  Battery Replacement: 步骤 9 中的图像 2,2
      • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
      询问修复机器人
      添加评论
    5. Samsung Galaxy Tab S3  Battery Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Tab S3  Battery Replacement: 步骤 10 中的图像 2,2
      • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
      询问修复机器人
      添加评论
    6. Samsung Galaxy Tab S3  Battery Replacement: 步骤 11 中的图像 1,1
      • The battery should now be removed and detached from the device.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
取消:我没有完成这个指南。
9等其他人完成本指南。
Mimi Rose
于04/18/18注册
684 声望
创作了4篇指南
团队
Cal Poly, Team S22-G4, Maness Spring 2018 Cal Poly, Team S22-G4, Maness Spring 2018 的会员
CPSU-MANESS-S18S22G4
5 名成员
创作了15篇指南
7指南评论
This repair can be done without removing the screen!
hansderaedt - 回复 分享
how? would it be simpler to do it that way?
Ryan McDaniel - 回复 分享
There is no reason to remove the screen. It’s super risky to do it that way. When you take the battery out, just use some alcohol on the sides of the battery to weaken the adhesive and use a suction cup to pull the battery out. No need to push on it from the screen side.
Nick Youngstrom - 回复 分享
What I get for reading a guide before checking comment, TOTALLY unnecessary step in removing screen. LCD cost $220 on ebay….
Phenix City - 回复 分享
Un vrai tuto de merde avec lequel vous êtes assuré de niquer votre tablette !!! Je vous recommande expressément de rechercher sur youtube “ How to Replace Your Samsung Galaxy Tab S3 SM-T825 Battery “ pour trouver un VRAI TUTO simple et qui vous évitera à coup sur de flinguer votre écran.
P de Rochefort
psurbook - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 137
总计 28,385
