跳转到主内容
Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement
你所需要的
  1. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Heat the iOpeners in a microwave for 1-2 minutes.
    • The iOpeners will be hot. Use caution and hold the tabs on the ends.
    • Place heated iOpeners on screen edges to heat the adhesive.
    • For more detailed instructions on how to use the iOpeners, please refer to the iOpener Instructions.
  2. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: 步骤 2 中的图像 1,1
    • Separate the screen assembly from the back by wedging the picks between the two components.
    • Slide the picks along the edge and leave them holding the device open all around the edges.
  3. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: 步骤 3 中的图像 1,1
    • Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
    • Insert the picks to hold the two components apart once a gap is created.
  4. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: 步骤 4 中的图像 1,1
    • Once all edges have been disconnected, carefully lift the screen off by pulling one side up.
    • Be careful not to cut yourself. Any broken glass from the screen will be sharp.
  5. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the tweezers, gently peel up on the silver tape covering the connector.
  6. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to get under the connector piece. This will allow you to remove the front panel assembly from the rest of the device.
  7. Samsung Galaxy Tab S2 9.7 SM-T813 Screen Replacement: 步骤 7 中的图像 1,1
    • Detach the connecter from the inside of the device.
    • Lift the screen to separate the front panel assembly from the rest of the device.
结论
12等其他人完成本指南。
Kaley Sapper
于04/18/18注册
787 声望
创作了2篇指南
团队
Cal Poly, Team S16-G5, Livingston Spring 2018 Cal Poly, Team S16-G5, Livingston Spring 2018 的会员
CPSU-LIVINGSTON-S18S16G5
5 名成员
创作了12篇指南
3条评论
Question. How is the new LCD re-attached? Do you reheat the old adhesive so that it sticks to the new LCD? Or do you need to apply new adhesive? Or is there a double-sided tape to re-attach the new LCD?
Dick Campbell - 回复
Hi,
my glass broke, not the LCD itself. Do you know how to separate LCD and glass, change the glass, and put it back again?
I have found a video on the internet but a laminating machine seems needed?? Any easier solution?
Thanks
Stefano Vaccarone - 回复
I would like to know also
Chris -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 67
总计 11,030
