跳转到主内容
Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement
你所需要的
  1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: 步骤 1 中的图像 1,2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: 步骤 1 中的图像 2,2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 2 中的图像 2,2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 3 中的图像 1,1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 5 中的图像 1,1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: 步骤 6 中的图像 1,2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: 步骤 6 中的图像 2,2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 7 中的图像 3,3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: 步骤 8 中的图像 1,2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: 步骤 8 中的图像 2,2
    • Locate the speakers towards the bottom.
    • For the speaker on the left, use the plastic opening tool to lift up the press-fit connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 9 中的图像 1,2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 9 中的图像 2,2
    • Apply the iOpener to the magnet to loosen the adhesive glue.
    • Refer to the iOpener guide for more help.
    • If you do not have access to an iOpener, you may also use a heat gun or a hair dryer.
  10. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using the precision tweezers, remove the speaker.
  11. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 11 中的图像 2,2
    • For the speaker on the right, use the plastic opening tool to lift up the press-fit connector.
    • Using the precision tweezers, detach the orange cable.
  12. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 12 中的图像 1,1
    • Pull the orange ribbon cable out of the ZIF connector using the precision tweezers.
    • Be gentle so that you do not damage the orange ribbon cable.
  13. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: 步骤 13 中的图像 1,1
结论
3等其他人完成本指南。
Joy Harris
于02/15/17注册
814 声望
创作了7篇指南
团队
USF Tampa, Team S3-G4, Sullivan Spring 2017 USF Tampa, Team S3-G4, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S3G4
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 1,259
