跳转到主内容
Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement
你所需要的
  1. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 2 中的图像 2,2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: 步骤 3 中的图像 1,3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: 步骤 3 中的图像 2,3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 7 中的图像 1,1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 8 中的图像 1,3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 8 中的图像 2,3 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement: 步骤 8 中的图像 3,3
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
  9. Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: 步骤 9 中的图像 1,2 Samsung Galaxy Tab E Lite 7 Kids Charging Port Replacement, Charging Port: 步骤 9 中的图像 2,2
    • Use a soldering iron to heat 4 spots of solder from the motherboard.
    • To learn more about soldering, check out iFixit's soldering technique guide.
    • Use precision tweezers to remove the charging port.
结论
另外一个人完成了本指南。
Nicholas Nolan
于02/17/17注册
805 声望
创作了5篇指南
团队
USF Tampa, Team S19-G2, Hoffman Spring 2017 USF Tampa, Team S19-G2, Hoffman Spring 2017 的会员
USFT-HOFFMAN-S17S19G2
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 6,565
