跳转到主内容
Samsung Galaxy Tab 3 Lite Battery Replacement
你所需要的
  1. Samsung Galaxy Tab 3 Lite Battery Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung Galaxy Tab 3 Lite Battery Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung Galaxy Tab 3 Lite Battery Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
    • This is a long process, so don't try and rush it. Also, be careful about applying pressure.
  2. Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 2 中的图像 3,3
    • After separating the tape holding the screen and case together, slowly start taking the screen off the case from the opposite side of the side with the buttons
  3. Samsung Galaxy Tab 3 Lite Battery Replacement, Battery: 步骤 3 中的图像 1,3 Samsung Galaxy Tab 3 Lite Battery Replacement, Battery: 步骤 3 中的图像 2,3 Samsung Galaxy Tab 3 Lite Battery Replacement, Battery: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the ZIF ( zero insertion force) connector highlighted by the red circle, as shown in the provided picture.
    • Use the plastic opening tool to gently lift the black ZIF connector shown within the red circle. It should just pop out with relative ease.
    • Use the precision tweezers and gently pull out the black cable out of its slot.
  4. Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 4 中的图像 2,2
    • Use the plastic opening tool to gently lift black flap shown within the red circle. It should just pop out with relative ease.
    • Now gently pull out the yellowish orange ribbon cable, similar to how you did in Step 1.
  5. Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy Tab 3 Lite Battery Replacement: 步骤 5 中的图像 3,3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
    • It should come off with no extra effort, since both the black and yellowish orange cables have been pulled out.
结论
15等其他人完成本指南。
Kevin Hicks
于02/09/16注册
1,575 声望
创作了2篇指南
团队
USF Tampa, Team 11-1, Cheng Spring 2016 USF Tampa, Team 11-1, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 64
总计 13,733
