当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
21等其他人完成本指南。
7条评论
Dear John,
Why must one disconnet the battery in step 3 and 4, whilst that does not seem necessary to replace the cable & port for the charger only (steps 5-10), and NOT the battery....?
Regards, Frank
Does the P5100 have the same charging port as the P7500?
I always open the tablet and order the cable by part and rev number. you may order a part for a tablet and will most like be sent for a diff version.
Oscar C -
