跳转到主内容
Samsung Galaxy Tab A 10.1 S-Pen Speaker Replacement
你所需要的
  1. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 3 中的图像 3,3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
  5. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 5 中的图像 2,2
    • Remove the ribbon cable from the socket.
  6. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4mm Phillips #000 screws from the speakers.
  7. Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 7 中的图像 1,2 Samsung Galaxy Tab  A 10.1 S-Pen Speaker Replacement: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to pry the speakers out of the tablet
结论
2等其他人完成本指南。
Guneet Bawa
于04/12/18注册
688 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018 的会员
UWT-LINER-S18S1G5
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 367
