跳转到主内容
Samsung Galaxy S7 Home Button Replacement
你所需要的
视频介绍
结论
2等其他人完成本指南。
MovilOne
于06/17/14注册
2,480 声望
创作了11篇指南
5指南评论
Hi,
Recently screen replaced with new homebutton - now fingerprint sensor is only giving error, any way to fix this?
Phone is rooted and has cust.firmware installed.
Try to fix :
factory defaults
reboots
cleared cache
Thanks for your reply!
Patrick Pieck - 回复
Thanks for you info.
www.movilone.es
MovilOne - 回复
hi finger scanner is not working but home button is work please suggest me
Shamim Akhtar - 回复
its cause the fingerprint sensor is synced with your logic board, you would have to write a script for it to work… which in that case would make you the first one to do so
Eric Touzin -
I need to replace the board of charger port with the module antenne, so I need to disamble the screen and don't know a what temperature I have to put the blower to not damage the LCD screen.
Joe Morel - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 17,835
