当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
使用一个撬棒的平端断开USB板连接器。
断开前面对面摄像机排线接头。
断开耳机扬声器排线连接器。
断开耳机插孔总成的排线接头。
断开显示器/数字化器排线连接器。
断开天线排线接头。
Prepare an iOpener (or use a hair dryer or heat gun) and heat the screen side of the phone to loosen the display adhesive.
Leave the iOpener on the phone for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
Because the gap between the screen and phone frame is so thin, a Jimmy is needed to separate the two. Read the following warnings carefully before proceeding.
Even though the metal blade is mostly dull, be careful not to apply too much pressure, as this might cause the Jimmy to slip and cut you or damage the phone.
Wear eye protection . The glass may break, sending pieces flying.
With the adhesive lose, insert the blade into the small gap between the frame and the screen, near the volume rocker.
Slowly slide the blade down the length of the phone towards the charge port to release the screen glass from the LCD.
The glass will most likely develop hairline fractures as you bend it during this step. Make sure you have proper eye protection.
The next three steps involve removing extremely fragile components. Consider working on a surface that will be easy to clean up afterwards.
With the screen glass completely loosened around the edges, remove it from the phone.
The fragile LCD display underneath the glass has a tendency to shatter into small pieces . If in doubt, protect your hands with gloves.
Cover the LCD with tape to prevent the broken glass from spreading or falling out during removal.
Carefully peel the cracked LCD away from the frame.
If necessary, push the Jimmy between the LCD and the frame to loosen it from the adhesive.
Remove the LCD.
Use tweezers to remove all old adhesive from the phone case before installing the new display.
When you install the replacement display, feed the display cable through the hole on the rear of the case.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
