跳转到主内容
Samsung Galaxy Rush Rear Facing Camera Replacement
你所需要的
  1. Samsung Galaxy Rush Rear Facing Camera Replacement, Rear Facing Camera: 步骤 1 中的图像 1,2 Samsung Galaxy Rush Rear Facing Camera Replacement, Rear Facing Camera: 步骤 1 中的图像 2,2
    • Looking at the back of your phone, use your finger to remove the back cover
  2. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the battery.
  3. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 3 中的图像 1,1
    • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
  4. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 4 中的图像 2,2
    • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
  5. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 5 中的图像 1,2 Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using tweezers, gently lift connectors from motherboard.
    • A connector will be on the upper left
    • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
  6. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 6 中的图像 1,2 Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
    • These stay attached to the motherboard so be careful not to break them.
    • They are on the side of the phone.
  7. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 7 中的图像 1,1
    • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
  8. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 8 中的图像 1,1
    • Lift the motherboard upwards separating it from your screen.
  9. Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 9 中的图像 1,3 Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 9 中的图像 2,3 Samsung Galaxy Rush Rear Facing Camera Replacement: 步骤 9 中的图像 3,3
    • Hold the motherboard with the circuits facing towards you
    • Gently take the back camera with two fingers and pull up-wards. A wiggle may help.
结论
Matthew
于10/22/14注册
1 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 184
