跳转到主内容
Samsung Galaxy Note Headphone Jack and Earpiece Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
  2. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 2 中的图像 1,1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
  3. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 3 中的图像 1,1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
  4. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Midframe: 步骤 4 中的图像 1,1
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
  5. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 5 中的图像 1,1
    • Remove the stylus from the bottom of the phone.
  6. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 6 中的图像 3,3
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
  7. Samsung Galaxy Note Headphone Jack and Earpiece Replacement, Headphone Jack and Earpiece: 步骤 7 中的图像 1,1
    • Use the spudger to pry up the yellow ribbon cable.
  8. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 8 中的图像 1,1
    • Use the spudger to pry up the long, green ribbon next to the yellow one you just pried up.
    • Push the green ribbon back to access the black bracket underneath it.
  9. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 9 中的图像 1,1
    • Use your fingers to gently lift up the black bracket and set it aside.
  10. Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 10 中的图像 1,2 Samsung Galaxy Note Headphone Jack and Earpiece Replacement: 步骤 10 中的图像 2,2
    • Flip the spudger around and insert the pointy end into the headphone jack.
    • Lift the headphone jack directly upwards using the spudger as a lever. This will also remove the connected speaker.
    • The headphone jack and earpiece are held down with an adhesive, so removing them might take some force.
结论
David Ritter
于04/14/13注册
758 声望
创作了6篇指南
团队
Cal Poly, Team 3-45, Amido Spring 2013 Cal Poly, Team 3-45, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G45
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,069
