跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note Antenna Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Samsung Galaxy Note Antenna Replacement, Battery: 步骤 1 中的图像 1,3 Samsung Galaxy Note Antenna Replacement, Battery: 步骤 1 中的图像 2,3 Samsung Galaxy Note Antenna Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the screen is face-down and the camera is opposite you.
    • Insert the flat end of a spudger into the phone's top right rectangular slot.
    • Use the spudger as a lever to pry open the back of the phone.
    询问修复机器人
    添加评论
  2. Samsung Galaxy Note Antenna Replacement: 步骤 2 中的图像 1,1
    • With the spudger still inserted, carefully slide the spudger down the side of the phone.
    • Gently peel off the back cover with your hand.
    询问修复机器人
    添加评论
  3. Samsung Galaxy Note Antenna Replacement: 步骤 3 中的图像 1,1
    • Place the spudger in the battery's bottom right slot.
    • Gently pry to remove the battery.
    询问修复机器人
    添加评论
  4. Samsung Galaxy Note Antenna Replacement, Midframe: 步骤 4 中的图像 1,1
    • Remove the nine 3mm screws on the perimeter of the phone with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  5. Samsung Galaxy Note Antenna Replacement: 步骤 5 中的图像 1,1
    • Remove the stylus from the bottom of the phone.
    询问修复机器人
    添加评论
  6. Samsung Galaxy Note Antenna Replacement: 步骤 6 中的图像 1,3 Samsung Galaxy Note Antenna Replacement: 步骤 6 中的图像 2,3 Samsung Galaxy Note Antenna Replacement: 步骤 6 中的图像 3,3
    • Pry all the way around the sides with a plastic pry tool and gently pop off the midframe.
    • If the cover does not come off easily, continue to pry along the phone's perimeter.
    • This step can take some patience. Prying too hard or forcing the screen off can crack or scratch the screen and break the thin plastic around the stylus case.
    • Separate the midframe from the phone. The midframe should now pull off easily.
    询问修复机器人
    添加评论
  7. Samsung Galaxy Note Antenna Replacement, Antenna: 步骤 7 中的图像 1,1
    • Remove the two 3mm screws surrounded by a gold border with a Phillips #00 screwdriver.
    询问修复机器人
    添加评论
  8. Samsung Galaxy Note Antenna Replacement: 步骤 8 中的图像 1,2 Samsung Galaxy Note Antenna Replacement: 步骤 8 中的图像 2,2
    • Use the spudger to pry up all six flex ribbons that hold the motherboard in place. They should pop off easily.
    询问修复机器人
    添加评论
  9. Samsung Galaxy Note Antenna Replacement: 步骤 9 中的图像 1,1
    • Use the spudger to pull off the white wire with the gold connector.
    询问修复机器人
    添加评论
  10. Samsung Galaxy Note Antenna Replacement: 步骤 10 中的图像 1,1
    • Lift the motherboard (PCB) directly up with your hands.
    • If the screws are all removed, the motherboard should come off easily.
    询问修复机器人
    添加评论
  11. Samsung Galaxy Note Antenna Replacement: 步骤 11 中的图像 1,2 Samsung Galaxy Note Antenna Replacement: 步骤 11 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three 3mm screws on the black rectangular bracket located towards the bottom of the phone.
    询问修复机器人
    添加评论
  12. Samsung Galaxy Note Antenna Replacement: 步骤 12 中的图像 1,1
    • Use the spudger's flat end to disconnect the other end of the antenna.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
13等其他人完成本指南。
团队
Cal Poly, Team 3-45, Amido Spring 2013 Cal Poly, Team 3-45, Amido Spring 2013 的会员
CPSU-AMIDO-S13S3G45
4 名成员
创作了28篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 4,906
