简介
Use this guide to replace the Micro-USB port daughterboard in your Galaxy Note 4.
你所需要的
Use a fingernail or vinyl spudger to easily remove the back cover of the device. Remove the S-Pen, battery, SIM card and MicroSD card (if present).
Free the clasps along the battery slot. And the push the front assembly out from middle housing with effort.
We can see the USB board but we can't tear it down directly. Because 1. The USB board flex connector is connecting on the back of the motherboard. 2. If want to remove motherboard, the LCD screen need to be removed at first. 3. The USB board assembly comes with two touch keys together but they are placed under the touch panel.
So we have to remove the motherboard and LCD screen at first next.
Cut the adhesive under the screen, release the connectors and remove the LCD screen. You can see more details when remove the LCD screen at Samsung Galaxy Note 4 LCD screen replacement guide.
Loosen the touch keys from adhesive at first. And then pry up and remove the USB board finally.
It's complicated to do Samsung Galaxy Note 4 USB board assembly replacement. We have to replace the LCD screen and motherboard at first, please be careful.
Good , bermanfaat sekali
For anyone having problems connecting the pins at the back of the motherboard, specially that pin the is next to the power button, stick something small and nonflammable the pin of the screen. Since this pin has a lot of play in some cases, sticking something under it will bring it up, making the motherboard connect with the LCD screen pin.
54等其他人完成本指南。
8条评论
charging port from 910C will be suitable to 910F model? Pls answer
After replacing USB ass'y, my AT&T phone does not recognize the Sim being installed.
Any suggestions?
Dan
I completed this but opted not to remove the LCD but just pry it up just enough to slide the touch buttons out and in and the work just fine. Thanks for the guide, everyone here is awesome!!!
thanks for the guide awesome!! yep i do like Kyle just remove the LCD just enough to slide the touch buttons xD
Broke the screen trying to remove it. Learned about 5 minutes later that I could've just heated up the end instead. This guide should be updated.
