跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
更换三星Galaxy Note 4的电池
你所需要的
  1. 更换三星Galaxy Note 4的电池, 后盖: 步骤 1 中的图像 1,2 更换三星Galaxy Note 4的电池, 后盖: 步骤 1 中的图像 2,2
    • 将指甲或塑料开启工具插入后置摄像头左侧的凹槽中。
    • 轻轻地将弹性后盖从手机背面撬起并弯曲。
  2. 更换三星Galaxy Note 4的电池, 电池: 步骤 2 中的图像 1,1
    • 将指甲或塑料开启工具插入电池右下角的凹槽中,向上掀起。
结论
要重新组装设备,请按照相反的顺序执行这些说明。
54等其他人完成本指南。
由衷感谢以下译者:
en zh
60%
Dorothy Boyd正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Geoff Wacker
于09/30/13注册
90,038 声望
创作了89篇指南
9条评论
I updated my phone and the problem is that my phone just goes all black all the time and my phone it won't turn on and sometimes my phone restarts by itself and after the carrier goes on and on after a few mins it repeatedly goes black.
Can someone please me what's wrong with my phone. I have a Samsung Note 4.
Jessica Lee - 回复
Seems like your mobile device may be stuck in whats called, BootLoop Mode.
Gabe -
Yeah. One time my Note 4 did that too. It has an Otter case. What happened was I put the phone in topside down position into the rubber part. By mistake, of course. Corrected that and the problem was solved.
Tony -
Each time I trimmed my nails. It was impossible to open the back cover and had to use a mini screwdriver to open. Quite inconvenient. So I attached a small piece of clear packing tape (not the flimsy Scotchtape) to the inside of the cover's recess, with enough length sticking out to the side. Grab that tape and pull back on the cover. Voila. The otter case covers the tape, so the phone looks normal in use.
Tony -
hi
can i now its Compatibility with note 4 ( 2 sim ) ???? or Compatibility with 1 sim ????
aigoostore - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 26
过去 30 天: 117
总计 33,110
