跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 4 Battery Replacement
你所需要的
  1. Samsung Galaxy Note 4 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
结论
56等其他人完成本指南。
Geoff Wacker
于09/30/13注册
92,727 声望
创作了89篇指南
9指南评论
I updated my phone and the problem is that my phone just goes all black all the time and my phone it won't turn on and sometimes my phone restarts by itself and after the carrier goes on and on after a few mins it repeatedly goes black.
Can someone please me what's wrong with my phone. I have a Samsung Note 4.
Jessica Lee - 回复 分享
Seems like your mobile device may be stuck in whats called, BootLoop Mode.
Gabe - 回复 分享
Yeah. One time my Note 4 did that too. It has an Otter case. What happened was I put the phone in topside down position into the rubber part. By mistake, of course. Corrected that and the problem was solved.
Tony - 回复 分享
Each time I trimmed my nails. It was impossible to open the back cover and had to use a mini screwdriver to open. Quite inconvenient. So I attached a small piece of clear packing tape (not the flimsy Scotchtape) to the inside of the cover's recess, with enough length sticking out to the side. Grab that tape and pull back on the cover. Voila. The otter case covers the tape, so the phone looks normal in use.
Tony - 回复 分享
hi
can i now its Compatibility with note 4 ( 2 sim ) ???? or Compatibility with 1 sim ????
aigoostore - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 116
总计 35,500
