跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Note 10.1 2014 Screen Replacement
你所需要的
  1. Samsung Galaxy Note 10.1 2014 Screen Replacement, Case: 步骤 1 中的图像 1,2 Samsung Galaxy Note 10.1 2014 Screen Replacement, Case: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Screen Replacement, Battery: 步骤 2 中的图像 1,1
    • Place your finger on the thin black bar at the end of the ribbon tape and flip each one up.
    • Gently pull the ribbon tape on the battery away from the bar. Repeat this process for the second ribbon tape.
  3. Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #000 Screwdriver
    $5.49
  4. Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Lift up the battery from the bottom and situate the black nylon spudger underneath the battery.
    • Use the black nylon spudger to disconnect the multi-colored wires from the rest of the device.
  5. Samsung Galaxy Note 10.1 2014 Screen Replacement, Loudspeaker Modules: 步骤 5 中的图像 1,2 Samsung Galaxy Note 10.1 2014 Screen Replacement, Loudspeaker Modules: 步骤 5 中的图像 2,2
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
  6. Samsung Galaxy Note 10.1 2014 Screen Replacement, loudspeaker  - remove right speaker: 步骤 6 中的图像 1,3 Samsung Galaxy Note 10.1 2014 Screen Replacement, loudspeaker  - remove right speaker: 步骤 6 中的图像 2,3 Samsung Galaxy Note 10.1 2014 Screen Replacement, loudspeaker  - remove right speaker: 步骤 6 中的图像 3,3
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
  7. Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 7 中的图像 1,3 Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 7 中的图像 2,3 Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 7 中的图像 3,3
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
  8. Samsung Galaxy Note 10.1 2014 Screen Replacement, Rear Camera: 步骤 8 中的图像 1,2 Samsung Galaxy Note 10.1 2014 Screen Replacement, Rear Camera: 步骤 8 中的图像 2,2
    • Disconnect the camera piece from the motherboard.
    • The camera piece is shaped like an "L".
  9. Samsung Galaxy Note 10.1 2014 Screen Replacement, Motherboard: 步骤 9 中的图像 1,3 Samsung Galaxy Note 10.1 2014 Screen Replacement, Motherboard: 步骤 9 中的图像 2,3 Samsung Galaxy Note 10.1 2014 Screen Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Disconnect all cables on the motherboard.
    • See our connector guide for help safely disconnecting various types of connectors.
  10. Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 10 中的图像 1,3 Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 10 中的图像 2,3 Samsung Galaxy Note 10.1 2014 Screen Replacement: 步骤 10 中的图像 3,3
    • Use the black nylon spudger to gently lift the motherboard away from the frame.
    • Remove the motherboard.
  11. Samsung Galaxy Note 10.1 2014 Screen Replacement, sreen - remove middle frame: 步骤 11 中的图像 1,1
    • remove middle frame by pulling it off
    • follow as shown on TechGuru.gr
    • Screen burst, be aware of glass splinters. May you cover the screen with tissue
  12. Samsung Galaxy Note 10.1 2014 Screen Replacement, screen - seperate buttons from screen: 步骤 13 中的图像 1,1
    • buttons are glued to frame, gently lift up screen
    • pull of cable, connecting the buttons, gently
  13. Samsung Galaxy Note 10.1 2014 Screen Replacement, screen - clean: 步骤 14 中的图像 1,1
    • rub of the glue with the fingers
    • remove residues with makeup remover or similar
结论
9等其他人完成本指南。
Stefn Mueller
于12/23/15注册
403 声望
撰写一个指南
4指南评论
is the digitizer glued to the lcd screen?
Amiel D Hechanova - 回复 分享
it is see referenced YouTube video
https://tinyurl.com/yccgecgh
Stefn Mueller - 回复 分享
The e battery and screen cable clasps that hold tge cables in….. Where do i get them repaired
Paul Brook - 回复 分享
Hi can somebody help me
Paul Brook - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 52
过去 30 天: 135
总计 11,701
