简介
Use this guide to replace the front case on your Galaxy Book Pro 360 15" laptop with a genuine Samsung part.
The front case consists of the keyboard and touchpad pre-installed into the frame. Make sure you have the right part before you begin the repair.
Before you begin, refer to the Samsung PC Repair Guide for safety information.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of a thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Note: Some photos show the heat sink and primary SSD removed. This is optional, as you don't need to remove the heat sink or the primary SSD to remove the motherboard.
你所需要的
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the rear case.
Apply a suction handle to the middle of the rear case's bottom edge, as close to the edge as possible.
Pull up on the handle with a strong, steady force to create a small gap between the rear case and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick along the bottom edge to release the clips securing the rear case.
Continue sliding the pick along the perimeter of the laptop until all the clips securing the rear case have been released.
Insert the flat end of a spudger under the battery cables, as close to the connector as possible.
Gently pry up and disconnect the battery connector from its socket.
Use a Phillips screwdriver to remove the four 4.5 mm screws securing the battery.
Use the pointed end up a spudger to pry up the locking flap on the left fan cable's ZIF connector.
Use the flat end of spudger to pry up and disconnect both of the interconnect cable's press connectors from the daughterboard.
Use the pointed end of a spudger to pry up and disconnect the bottom left speaker's connector from the daughterboard.
Lift the right side of the daughterboard up and pull towards the center of the laptop to remove it.
Move all cables that connect to the daughterboard (display, fingerprint, interconnect, speaker, backlight, and antennas) out of the way so they don't get stuck under the daughterboard when it's reinserted.
Reinsert the daughterboard at a downward angle to position the headphone jack, USB-C port, and memory slot back into their recesses.
Before securing the daughterboard, make sure the alignment pins on the frame are in their cutouts on the daughterboard.
Use a Phillips #00 screwdriver to remove the three 2.5 mm screws securing the fingerprint sensor bracket on the top left corner of the laptop.
Use tweezers or your fingers to remove the fingerprint sensor.
Use the pointed end of a spudger to pry up the locking flap on the right fan cable's ZIF connector.
Use the pointed end of a spudger to pry up and disconnect the bottom right speaker's connector from the motherboard.
Use the flat end of a spudger to pry up the locking flap on the keyboard cable's ZIF connector.
Grip the keyboard cable's pull tab with tweezers or your fingers and gently pull the cable out of its socket.
Use the flat end of a spudger to pry up the locking flap on the touchpad's ZIF connector on the motherboard.
Grip the touchpad cable's pull tab with tweezers and gently pull the cable out of its socket on the motherboard.
Lift the motherboard straight up and remove it.
Move all cables that connect to the motherboard (display, keyboard, speaker, and antenna) out of the way so they don't get stuck under the motherboard when it's reinserted.
Make sure the alignment pins on the frame are in their cutouts on the motherboard.
Push down on right edge of the motherboard to ensure the USB-C and thunderbolt ports are in their recesses.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
