跳转到主内容
Samsung Galaxy A3 2016 Back Cover Replacement
你所需要的
  1. Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: 步骤 1 中的图像 1,3 Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: 步骤 1 中的图像 2,3 Samsung Galaxy A3 2016 Back Cover Replacement, Back cover: 步骤 1 中的图像 3,3
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • Lift the bottom part of your back cover with a suction handle and insert an opening pick.
  2. Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 2 中的图像 3,3
    • Slide the opening pick up to the rear camera to separate the back cover from the frame.
  3. Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 3 中的图像 1,2 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 3 中的图像 2,2
    • Insert a second opening pick and move around the other corner at the bottom part of the back cover.
  4. Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 4 中的图像 1,3 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 4 中的图像 2,3 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 4 中的图像 3,3
    • Move the second pick along the left side of the back cover to loosen the adhesive.
    • Move around the upper left corner and loosen the adhesive above the rear camera.
    • After loosening all the edges and sides of the back cover use an iOpener to loosen the adhesive underneath the center of it.
  5. Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 5 中的图像 1,3 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 5 中的图像 2,3 Samsung Galaxy A3 2016 Back Cover Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • Insert a plastic card at the bottom and slide it underneath the back cover.
    • Separate the glue until you reach the rear camera.
    • Now you can slowly lift up the back cover and finally remove it.
结论
17等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
228,990 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,418篇指南
一条评论
where can I buy the back cover? tnx
rompecolleoni - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 16
过去 30 天: 35
总计 16,957
