跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy A3 (2017) Display Replacement
你所需要的
  1. Samsung Galaxy A3 (2017) Display Replacement, Back cover replacement: 步骤 1 中的图像 1,1
    • Power off your phone before beginning disassembly.
    • Use an iOpener to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • The adhesive of the Samsung Galaxy A3 (2017) is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    添加评论
  2. Samsung Galaxy A3 (2017) Display Replacement: 步骤 2 中的图像 1,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 2 中的图像 2,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 2 中的图像 3,3
    • Use a small suction handle to create a gap at the bottom end of the Galaxy A3.
    • Insert an opening pick and slide the tip to the bottom left corner to cut the adhesive.
    • Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
    • Insert a new opening pick and start to cut the adhesive towards the bottom left side of the phone.
    询问修复机器人
    添加评论
  3. Samsung Galaxy A3 (2017) Display Replacement: 步骤 3 中的图像 1,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 3 中的图像 2,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 3 中的图像 3,3
    • Use an opening pick to cut the adhesive on all sides of the phone. Leave one opening pick in every corner to prevent the adhesive from resealing.
    • Reuse an iOpener if the adhesive becomes hard to cut. During the removal process the back cover is under tension all the time and is likely to break if the adhesive isn't loose enough.
    • Insert an opening pick on the right side of the phone after you cut the adhesive on all sides. Flip it sideways until you can get a good grip on the back cover.
    询问修复机器人
    添加评论
  4. Samsung Galaxy A3 (2017) Display Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover from the phone.
    • Before applying new adhesive remove any remaining adhesive from the back cover and the frame and clean the areas with isopropyl alcohol and a lint-free cloth.
    询问修复机器人
    添加评论
  5. Samsung Galaxy A3 (2017) Display Replacement, Motherboard cover including NFC antenna and loudspeaker replacement: 步骤 5 中的图像 1,1
    • Remove the five Phillips #00 screws that hold the motherboard covers in their place.
    询问修复机器人
    添加评论
  6. Samsung Galaxy A3 (2017) Display Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the upper part of the motherboard cover.
    • The cover is secured by small plastic clamps. Don't break them during the removal procedure.
    询问修复机器人
    添加评论
  7. Samsung Galaxy A3 (2017) Display Replacement: 步骤 7 中的图像 1,1
    • Use a pair of tweezers to lift up the motherboard cover including the loudspeaker and the NFC antenna and remove it.
    询问修复机器人
    添加评论
  8. Samsung Galaxy A3 (2017) Display Replacement, Battery Disconnect: 步骤 8 中的图像 1,1
    • Use the flat end of a spudger to disconnect the battery flex connector.
    询问修复机器人
    添加评论
  9. Samsung Galaxy A3 (2017) Display Replacement, Display: 步骤 9 中的图像 1,1
    • Use the flat end of a spudger to disconnect the display flex cable.
    询问修复机器人
    添加评论
  10. Samsung Galaxy A3 (2017) Display Replacement: 步骤 10 中的图像 1,1
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    询问修复机器人
    添加评论
  11. Samsung Galaxy A3 (2017) Display Replacement: 步骤 11 中的图像 1,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 11 中的图像 2,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 11 中的图像 3,3
    • Once the display is warm to the touch, apply a suction cup to the upper edge of the phone.
    • Lift on the suction cup, and insert an opening pick under the display assembly.
    • Start to slide the opening pick along the upper edge of the phone to cut the adhesive. Leave an opening pick at the corner to prevent the adhesive from resealing.
    • Continue to cut the adhesive on the remaining sides of the phone and leave an opening pick in each corner.
    • The home button and soft key cables are located beneath the bottom part of the display assembly. Only insert the tip of the opening pick.
    询问修复机器人
    添加评论
  12. Samsung Galaxy A3 (2017) Display Replacement: 步骤 12 中的图像 1,2 Samsung Galaxy A3 (2017) Display Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
    • After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
    询问修复机器人
    添加评论
  13. Samsung Galaxy A3 (2017) Display Replacement: 步骤 13 中的图像 1,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 13 中的图像 2,3 Samsung Galaxy A3 (2017) Display Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    • Don't open the phone all the way yet. The display cable is still threaded through the mid frame and you might rip the cables of the home and menu buttons.
    • Start to carefully lift the upper edge of the display assembly and thread the display flex cable through the mid frame.
    • Check if the home button or soft key button cables stick to the display assembly before your remove the display all the way.
    • In case one of the cables sticks to the display, carefully peel them off with a pair of tweezers or an opening pick.
    • Remove the display assembly from the phone.
    • Before reassembling make sure to remove any remaining adhesive from the frame by using isopropyl alcohol (>97%) and a lint-free cloth or Q-tip.
    询问修复机器人
    添加评论
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the mid frame. Align the screen and press it into place.
取消:我没有完成这个指南。
19等其他人完成本指南。
团队
iFixit iFixit 的会员
Staff
122 名成员
创作了27,525篇指南
5指南评论
Does anyone know if or how you can get the AMOLED display the SM-A320FL had originally.
Thank you.
A McGovern - 回复 分享
Ich scheitere bereits am ersten Schritt: Ich erhitze die Rückseite gleichmäßig mit einer kleinen Heißluftpistole bis ich Sie nicht mehr anfassen kann, also deutlich über 70°C. Dennoch schaffe ich es auch mit äußerster Kraft nicht, die Rückwand unten mittig nur den Bruchteil eines Millimeters anzuheben.
Ralf Reuschling - 回复 分享
Hallo Ralf,
wenn das Gerät oder die Heißluftpistole zu heiß wird ist das natürlich nicht gut. Manchmal kann der verwendete Klebstoff sehr widerspenstig sein. Du kannst versuchen eine Spielkarte in die Lücke zwischen Rückseite und Rahmen zu pressen oder an einer der Kanten entlang zu ziehen. Versuche so eine kleine Stelle des Klebstoffs zu durchtrennen um danach ein Opening Pick anzusetzen. Sollte die Spielkarte nicht stabil genug sein, ist der letzte Ausweg eine dünne Klinge von einem Cutter-Messer o.ä. Sei hierbei jedoch äußerst vorsichtig da du damit sehr schnell Kratzer in dein Gerät schneidest und Verletzungsgefahr besteht. Verwende nachdem du mit dem Messer einen kleinen Spalt geschaffen hast am besten sofort wieder Plastikwerkzeug um Schäden am Telefon zu vermeiden.
Dominik Schnabelrauch - 回复 分享
Danke, ich habe es schlussendlich doch geschafft - mit etwas mehr Wärme und einem stärkeren Sauger.
I used a hot air heater on 110 degrees Celcius, worked fine.
Dennis van der Pool - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 89
总计 19,078
