跳转到主内容
Samsung Galaxy A20 Charging Port Replacement
你所需要的
  1. Samsung Galaxy A20 Charging Port Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung Galaxy A20 Charging Port Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung Galaxy A20 Charging Port Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Unplug and power off the device before beginning.
    • Remove the SIM card and the SIM card tray.
    • Use an iOpener or heat gun to warm the adhesive that secures the back cover.
    • Insert an opening pick in the seam between the back cover and chassis while the adhesive is warm.
    • Slide the pick around the entire perimeter.
    • If you encounter notable resistance, reheat the adhesive. Do not attempt to sever cold adhesive.
    • Remove the back cover.
  2. Samsung Galaxy A20 Charging Port Replacement, I/O Board: 步骤 2 中的图像 1,2 Samsung Galaxy A20 Charging Port Replacement, I/O Board: 步骤 2 中的图像 2,2
    • Remove all thirteen 3.6 mm Phillips screws that secure the midframe.
    • Use an opening pick to pry up and lift out the midframe.
  3. Samsung Galaxy A20 Charging Port Replacement: 步骤 3 中的图像 1,1
    • Use an opening tool to gently pry up the press connectors on both ends of the two ribbon cables.
  4. Samsung Galaxy A20 Charging Port Replacement: 步骤 4 中的图像 1,2 Samsung Galaxy A20 Charging Port Replacement: 步骤 4 中的图像 2,2
    • Disconnect the red antenna cable from the I/O board.
    • Use an opening pick to pry up and remove the I/O board.
  5. Samsung Galaxy A20 Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,2 Samsung Galaxy A20 Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,2
    • Desolderthe charging port.
    • Soldering can cause fires and burns. Always solder in a well-ventilated workspace.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 18
总计 32
