跳转到主内容
Samsung Epix LCD Display Replacement
你所需要的
  1. Samsung Epix LCD Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix LCD Display Replacement: 步骤 2 中的图像 1,1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix LCD Display Replacement, LCD Display: 步骤 3 中的图像 1,1
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: 步骤 5 中的图像 1,2 Samsung Epix LCD Display Replacement: 步骤 5 中的图像 2,2
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: 步骤 6 中的图像 1,1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: 步骤 7 中的图像 1,1
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: 步骤 8 中的图像 1,1
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: 步骤 9 中的图像 1,1
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: 步骤 10 中的图像 1,1
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: 步骤 11 中的图像 1,1
    • Lift the LCD display out from phone chassis.
结论
另外一个人完成了本指南。
Mark Wyse
于04/19/11注册
59 声望
创作了2篇指南
团队
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 的会员
CPSU-REGAN-S11S15G15
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,913
