跳转到主内容
Samsung Chromebook Plus Battery Replacement
你所需要的
  1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: 步骤 1 中的图像 1,1
    • Remove the 8 PHILIPS#0 screws
  2. Samsung Chromebook Plus Battery Replacement, Removing back panel: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: 步骤 3 中的图像 1,1
    • Use your PHILIPS#0 and remove the 4 screws
  4. Samsung Chromebook Plus Battery Replacement, Removing the battery: 步骤 4 中的图像 1,1
    • Lift battery from bottom side first (marked with red line)
  5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: 步骤 5 中的图像 1,1
    • Detach battery cable grabbing the side and pulling the cable upward.
  6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: 步骤 6 中的图像 1,1
    • Insert the battery and push the plug into the socket downward.
  7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: 步骤 7 中的图像 1,1
    • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: 步骤 8 中的图像 1,1
    • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
结论
To reassemble your device, skip steps 1-5.
7等其他人完成本指南。
Evan Elm
于12/31/17注册
1,023 声望
创作了3篇指南
团队
Kid fixers Kid fixers 的会员
Community
162 名成员
创作了300篇指南
6条评论
Great repair guide. Nice to see how easy it is to replace battery.
N ick - 回复
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - 回复
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
I managed to find a replacement part, see the parts section at the top of the guide :)
Evan Elm -
thanks for finding the battery part! Awesome job!
JT Cen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 52
总计 6,862
