跳转到主内容
Samsung BD-JM57C Open Button Replacement
你所需要的
  1. Samsung BD-JM57C Open Button Replacement, Top Cover: 步骤 1 中的图像 1,2 Samsung BD-JM57C Open Button Replacement, Top Cover: 步骤 1 中的图像 2,2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Open Button Replacement, Disc Drive: 步骤 2 中的图像 1,2 Samsung BD-JM57C Open Button Replacement, Disc Drive: 步骤 2 中的图像 2,2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Open Button Replacement: 步骤 3 中的图像 1,2 Samsung BD-JM57C Open Button Replacement: 步骤 3 中的图像 2,2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Open Button Replacement, WiFi Card: 步骤 4 中的图像 1,2 Samsung BD-JM57C Open Button Replacement, WiFi Card: 步骤 4 中的图像 2,2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Open Button Replacement, Power Cord: 步骤 5 中的图像 1,2 Samsung BD-JM57C Open Button Replacement, Power Cord: 步骤 5 中的图像 2,2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Open Button Replacement: 步骤 6 中的图像 1,1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Open Button Replacement: 步骤 7 中的图像 1,1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Open Button Replacement: 步骤 8 中的图像 1,1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  9. Samsung BD-JM57C Open Button Replacement, Motherboard: 步骤 9 中的图像 1,1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  10. Samsung BD-JM57C Open Button Replacement: 步骤 10 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  11. Samsung BD-JM57C Open Button Replacement: 步骤 11 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
  12. Samsung BD-JM57C Open Button Replacement, Open Button: 步骤 12 中的图像 1,1
    • Locate the Open Button on the circuit board.
  13. Samsung BD-JM57C Open Button Replacement: 步骤 13 中的图像 1,1
    • Flip the motherboard over so that the green side is facing you.
    • Use a soldering iron to desolder the two points to disconnect the open button.
    • For more information on soldering, please read the 如何焊接和拆焊 guide.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 1,367
