跳转到主内容
Samsung 27E510C Audio Jack Replacement
你所需要的
  1. Samsung 27E510C Audio Jack Replacement, Back Panel: 步骤 1 中的图像 1,3 Samsung 27E510C Audio Jack Replacement, Back Panel: 步骤 1 中的图像 2,3 Samsung 27E510C Audio Jack Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C Audio Jack Replacement: 步骤 2 中的图像 1,2 Samsung 27E510C Audio Jack Replacement: 步骤 2 中的图像 2,2
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C Audio Jack Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C Audio Jack Replacement: 步骤 4 中的图像 1,1
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C Audio Jack Replacement: 步骤 5 中的图像 1,3 Samsung 27E510C Audio Jack Replacement: 步骤 5 中的图像 2,3 Samsung 27E510C Audio Jack Replacement: 步骤 5 中的图像 3,3
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C Audio Jack Replacement: 步骤 6 中的图像 1,3 Samsung 27E510C Audio Jack Replacement: 步骤 6 中的图像 2,3 Samsung 27E510C Audio Jack Replacement: 步骤 6 中的图像 3,3
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C Audio Jack Replacement: 步骤 7 中的图像 1,2 Samsung 27E510C Audio Jack Replacement: 步骤 7 中的图像 2,2
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C Audio Jack Replacement, Audio Jack: 步骤 8 中的图像 1,2 Samsung 27E510C Audio Jack Replacement, Audio Jack: 步骤 8 中的图像 2,2
    • Desolder each of the indicated leads on the back of the motherboard.
  9. Samsung 27E510C Audio Jack Replacement: 步骤 9 中的图像 1,2 Samsung 27E510C Audio Jack Replacement: 步骤 9 中的图像 2,2
    • Squeeze the rear tabs located on the back of the motherboard with your thumb and index finger.
    • While squeezing both tabs, pull the audio jack out from the front of the motherboard.
    • The audio jack may be too hot to touch right after desoldering.
结论
Cesar Morales
于09/27/17注册
101 声望
撰写一个指南
团队
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S9G1
6 名成员
创作了14篇指南
一条评论
did you know port reference? @cesarmorales
Jorge Casanova - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 448
