跳转到主内容
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
你所需要的
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: 步骤 1 中的图像 1,2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 2 中的图像 1,3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 2 中的图像 2,3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 2 中的图像 3,3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 3 中的图像 1,3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 3 中的图像 2,3 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 3 中的图像 3,3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: 步骤 4 中的图像 1,2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: 步骤 4 中的图像 2,2
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 5 中的图像 1,2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 5 中的图像 2,2
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 6 中的图像 1,2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 6 中的图像 2,2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 7 中的图像 1,2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 7 中的图像 2,2
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 8 中的图像 1,1
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 步骤 9 中的图像 1,1
    • Remove the home button by sliding it to the left or right while pulling up.
结论
另外一个人完成了本指南。
Guneet Bawa
于04/12/18注册
670 声望
创作了4篇指南
团队
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018 的会员
UWT-LINER-S18S1G5
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 1,960
