跳转到主内容
Safely remove PC case stickers
你所需要的
  1. Safely remove PC case stickers, Remove the battery (Laptops only): 步骤 1 中的图像 1,2 Safely remove PC case stickers, Remove the battery (Laptops only): 步骤 1 中的图像 2,2
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. Safely remove PC case stickers, Warm up the adhesive: 步骤 2 中的图像 1,3 Safely remove PC case stickers, Warm up the adhesive: 步骤 2 中的图像 2,3 Safely remove PC case stickers, Warm up the adhesive: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    • 30-60 seconds of heat is sufficient.
    • If the sticker is thin, a guitar pick may help.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. Safely remove PC case stickers, Clean the remaining glue: 步骤 3 中的图像 1,3 Safely remove PC case stickers, Clean the remaining glue: 步骤 3 中的图像 2,3 Safely remove PC case stickers, Clean the remaining glue: 步骤 3 中的图像 3,3
    • While denatured alchol works, it may "strip" some rubber coatings and paint! Use good judgement!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
终点
6等其他人完成本指南。
Nick
于11/10/09注册
93,686 声望
创作了59篇指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,699篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 183
总计 17,095
