你所需要的
Prepare descaling liquid (see comments) and fill it into the water tank (as with the usual descaling according to the instructions)
Switch off the coffee machine
Press and hold the coffee and steam buttons while switching the machine on -> The test mode is activated
The test mode is not indicated by any LEDs. I found the information about the test mode on www.m-landmann.eu, among other things
Set volume control (green) to minimum (all the way to the left)
Press and hold the steam button until the LED next to the coffee cup lights up (yellow mark)
The brew group is now in the brewing position and the support valve (pink) is activated.
The quantity regulation remains at minimum.
Place a (large) empty cup under the spout
Press and hold the coffee button until the pump dispenses approximately one cup of liquid. For information: The error display flashes approx. 600 times for 200ml of water.
wait about 20 minutes ( to take full effect)
Pump out the rest of the descaling liquid in cups, pausing the pumping with 3-minute breaks.
Rinse out the water tank and fill it up with clear water
Pour off a few cups of water as in the last step, rinsing out the remains of the citric acid.
Set the volume control to the middle and hold down the steam button until the LED next to the coffee button lights up. The brew group is now back in its original position.
Switch off the machine and switch it on again as usual - Descaling complete.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
