跳转到主内容
Ryobi CSB135L Power Cord Replacement
你所需要的
  1. Ryobi CSB135L Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Place the saw on a flat surface.
    • Make sure the saw is unplugged and unpowered.
  2. Ryobi CSB135L Power Cord Replacement: 步骤 2 中的图像 1,2 Ryobi CSB135L Power Cord Replacement: 步骤 2 中的图像 2,2
    • Remove the six M4x16mm Phillips screws and the two M4.5x35mm screws using a Phillips #2 screwdriver.
    • Remove the front facing half of the handle assembly exposing the internals of the saw.
  3. Ryobi CSB135L Power Cord Replacement: 步骤 3 中的图像 1,2 Ryobi CSB135L Power Cord Replacement: 步骤 3 中的图像 2,2
    • After removing the handle assembly locate the trigger switch and wire nut in the saw.
    • Remove the screw from the black wire of the power cord using a Phillips screwdriver. Then remove the wire.
    • Loosen the wire nut and remove the neutral wire from the power cord.
  4. Ryobi CSB135L Power Cord Replacement: 步骤 4 中的图像 1,1
    • Remove the power cord from the saw.
    • To insert the replacement power cord, insert the black wire of the cord into the trigger switch and tighten the screw. Take the neutral/white wire of the new cord and insert it into the wire nut and tighten the nut.
    • Wire strippers may be needed when installing the new power cord to expose the copper wire.
结论
团队
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 168
