跳转到主内容
Ryobi CSB135L Guard Replacement
你所需要的
  1. Ryobi CSB135L Guard Replacement, Blade: 步骤 1 中的图像 1,2 Ryobi CSB135L Guard Replacement, Blade: 步骤 1 中的图像 2,2
    • Remove the central 6mm hex nut and two black washers using a 6mm allen wrench.
    • Remove the old blade.
    • The blade has already been removed from this device.
  2. Ryobi CSB135L Guard Replacement, Guard: 步骤 2 中的图像 1,1
    • Remove the M5 x 20 mm screw using a Phillips screwdriver.
    • Remove the black rubber stopper.
    • This allows for 360 degree rotation of the guard.
  3. Ryobi CSB135L Guard Replacement: 步骤 3 中的图像 1,2 Ryobi CSB135L Guard Replacement: 步骤 3 中的图像 2,2
    • Remove the four M4 x 16 mm screws holding the blade guard on using a Phillips screwdriver.
    • Rotate the guard as necessary to gain access to all the screws.
  4. Ryobi CSB135L Guard Replacement: 步骤 4 中的图像 1,1
    • Remove the guard setup
    • Adjusting the blade depth to allow more room near the guard housing can help with the removal
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-3, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G3
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 146
