简介
This guide will show you how to properly replace the blade on your Ryobi CSB135L. If the symptoms your Ryobi CSB135L is experiencing align with the symptoms of a dull blade in our troubleshooting page, your blade might be dull. This guide will walk you through how to replace the blade.
你所需要的
Remove the central 6mm hex nut and two black washers using a 6mm allen wrench.
Remove the old blade.
即将完成!
结论
另外一个人完成了本指南。
