跳转到主内容
Rydis H68 Pro Motherboard Replacement
你所需要的
  1. Rydis H68 Pro Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Rydis H68 Pro Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the vacuum over so that the wheels are facing you.
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws that surround the battery cover.
  2. Rydis H68 Pro Motherboard Replacement: 步骤 2 中的图像 1,1
    • Lift the battery cover up to reveal the battery.
    • Remove the battery.
  3. Rydis H68 Pro Motherboard Replacement, Bumper: 步骤 3 中的图像 1,3 Rydis H68 Pro Motherboard Replacement, Bumper: 步骤 3 中的图像 2,3 Rydis H68 Pro Motherboard Replacement, Bumper: 步骤 3 中的图像 3,3
    • Remove the eight 10 mm Phillips #1 screws.
  4. Rydis H68 Pro Motherboard Replacement: 步骤 4 中的图像 1,3 Rydis H68 Pro Motherboard Replacement: 步骤 4 中的图像 2,3 Rydis H68 Pro Motherboard Replacement: 步骤 4 中的图像 3,3
    • Hold the front bumper and pull it off.
    • It requires a lot of force to pull the bumper off.
  5. Rydis H68 Pro Motherboard Replacement: 步骤 5 中的图像 1,3 Rydis H68 Pro Motherboard Replacement: 步骤 5 中的图像 2,3 Rydis H68 Pro Motherboard Replacement: 步骤 5 中的图像 3,3
    • Pry off the back bumper by going around the entire top of the bumper with the metal spudger.
  6. Rydis H68 Pro Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,3 Rydis H68 Pro Motherboard Replacement, Motherboard: 步骤 6 中的图像 2,3 Rydis H68 Pro Motherboard Replacement, Motherboard: 步骤 6 中的图像 3,3
    • To access the motherboard, lift the top portion of the vacuum off.
  7. Rydis H68 Pro Motherboard Replacement: 步骤 7 中的图像 1,2 Rydis H68 Pro Motherboard Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws holding the motherboard in place.
  8. Rydis H68 Pro Motherboard Replacement: 步骤 8 中的图像 1,3 Rydis H68 Pro Motherboard Replacement: 步骤 8 中的图像 2,3 Rydis H68 Pro Motherboard Replacement: 步骤 8 中的图像 3,3
    • Pinch the two tabs together, shown here, to loosen the motherboard out of the vacuum.
    • Lightly pull on the USB connector shown to lift the motherboard out.
结论
另外一个人完成了本指南。
团队
USFT-Lacy-S17S005G2 USFT-Lacy-S17S005G2 的会员
Local Repair Groups
4 名成员
创作了10篇指南
3条评论
This was GREAT.... Lots of pics :-)
I was able to pull the mother board without much trouble. Mostly scared of breaking the connections.
NOW???? Where do I buy the darn thing?
Please respond,
Robert
Robert Kilgore - 回复
Unfortunately, it looks like Moneual had some fraud issues and went under in 2014. It may be difficult to get your hands on replacement parts for the Rydis H68 Pro. =[
Richard -
where are the internal batteries CR2032 ?? I have heard that problems maybe due to internal batteries and not motherboard. Unable to get top off.
Do you know how to do a factory reset ? thank you. N. Tribley Oct. 23
naomi - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 1,285
