跳转到主内容
加入维修社区 - 创建账户
Rotor Riot Face Button Replacement
你所需要的
  1. Rotor Riot Face Button Replacement, Remove the iPhone mount: 步骤 1 中的图像 1,3 Rotor Riot Face Button Replacement, Remove the iPhone mount: 步骤 1 中的图像 2,3 Rotor Riot Face Button Replacement, Remove the iPhone mount: 步骤 1 中的图像 3,3
    • Use your fingers to remove the screw on the back side of the controller securing the iPhone mount.
    • Remove the iPhone mount.
  2. Rotor Riot Face Button Replacement, Unscrew the back cover: 步骤 2 中的图像 1,1
    • Use a T6 Torx screwdriver to remove the eight 9.2 mm-long screws securing the back cover.
    • Don't try to remove the back cover all the way yet! It's still connected to the mainboard.
  3. Rotor Riot Face Button Replacement, Swing open the back cover: 步骤 3 中的图像 1,3 Rotor Riot Face Button Replacement, Swing open the back cover: 步骤 3 中的图像 2,3 Rotor Riot Face Button Replacement, Swing open the back cover: 步骤 3 中的图像 3,3
    • Lift up the back cover of the controller.
    • Lift the back cover to a 45 degree angle and place it next to the controller.
    • Don't strain the interconnect cable during this procedure.
  4. Rotor Riot Face Button Replacement, Disconnect the phone connector cable: 步骤 4 中的图像 1,3 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: 步骤 4 中的图像 2,3 Rotor Riot Face Button Replacement, Disconnect the phone connector cable: 步骤 4 中的图像 3,3
    • Use a spudger to disconnect the phone connector cable from the mainboard.
  5. Rotor Riot Face Button Replacement, Remove the back cover: 步骤 5 中的图像 1,1
    • Remove the back cover.
  6. Rotor Riot Face Button Replacement, Remove the shoulder buttons: 步骤 6 中的图像 1,2 Rotor Riot Face Button Replacement, Remove the shoulder buttons: 步骤 6 中的图像 2,2
    • Remove the shoulder buttons by lifting them out of the case.
  7. Rotor Riot Face Button Replacement, Unscrew the mainboard: 步骤 7 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 7.0 mm-long screws securing the mainboard.
  8. Rotor Riot Face Button Replacement, Flip over the mainboard: 步骤 8 中的图像 1,3 Rotor Riot Face Button Replacement, Flip over the mainboard: 步骤 8 中的图像 2,3 Rotor Riot Face Button Replacement, Flip over the mainboard: 步骤 8 中的图像 3,3
    • Flip over the mainboard and place it above the controller housing.
    • Avoid tensioning the trigger button cables during this procedure and don't try to remove the mainboard all the way yet! It is still connected to the controller housing.
  9. Rotor Riot Face Button Replacement, Remove the face buttons: 步骤 9 中的图像 1,2 Rotor Riot Face Button Replacement, Remove the face buttons: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the face buttons from the housing.
    • The alignment pegs on each button are designed to prevent incorrect installation. Make sure your new buttons fit properly in the controller case.
结论
Adriana Zwink
于12/18/19注册
63,632 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
125 名成员
创作了24,016篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 228
