跳转到主内容
Roku XD 2050X Composite Video Port Replacement
你所需要的
  1. Roku XD 2050X Composite Video Port Replacement, Case: 步骤 1 中的图像 1,3 Roku XD 2050X Composite Video Port Replacement, Case: 步骤 1 中的图像 2,3 Roku XD 2050X Composite Video Port Replacement, Case: 步骤 1 中的图像 3,3
    • Ensure the Roku XDis unplugged.
    • Take care when handling components. Circuit boards, soldering points, and other areas may have sharp points.
    • Turn the device upside down.
    • Remove the two rubber pads using a plastic spudger.
  2. Roku XD 2050X Composite Video Port Replacement: 步骤 2 中的图像 1,2 Roku XD 2050X Composite Video Port Replacement: 步骤 2 中的图像 2,2
    • Remove the two Phillips #1 9mm pan-head screws.
  3. Roku XD 2050X Composite Video Port Replacement: 步骤 3 中的图像 1,3 Roku XD 2050X Composite Video Port Replacement: 步骤 3 中的图像 2,3 Roku XD 2050X Composite Video Port Replacement: 步骤 3 中的图像 3,3
    • Insert spudger between upper and lower frame underneath the port access.
    • Guide spudger around to loosen upper and lower frame to pry frame apart.
    • Gently remove upper frame.
  4. Roku XD 2050X Composite Video Port Replacement: 步骤 4 中的图像 1,2 Roku XD 2050X Composite Video Port Replacement: 步骤 4 中的图像 2,2
    • Remove the two Phillips #1 8mm pan-head screws.
  5. Roku XD 2050X Composite Video Port Replacement: 步骤 5 中的图像 1,1
    • On the side of the board opposite the ports, find and tilt back the tab securing the board in place.
    • Lift the motherboard out of the lower frame.
  6. Roku XD 2050X Composite Video Port Replacement, Composite Video Port: 步骤 6 中的图像 1,1
    • Desolder the leads for the composite video port that are circled.
    • Remove the video port from the board.
    • For help with soldering view the iFixit soldering guide.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 614
