跳转到主内容
Roku 3 Ethernet Port Replacement
你所需要的
  1. Roku 3 Ethernet Port Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Place the Roku 3 on the table face down and orient it so you can correctly read the writing.
  2. Roku 3 Ethernet Port Replacement: 步骤 2 中的图像 1,3 Roku 3 Ethernet Port Replacement: 步骤 2 中的图像 2,3 Roku 3 Ethernet Port Replacement: 步骤 2 中的图像 3,3
    • Pull back the rubber protection in the top right corner to locate the screw.
    • Repeat with the bottom right corner and bottom left corner.
  3. Roku 3 Ethernet Port Replacement: 步骤 3 中的图像 1,1
    • Remove the 9 mm screws from the three corners with a Hex 1.3 Screwdriver.
  4. Roku 3 Ethernet Port Replacement: 步骤 4 中的图像 1,2 Roku 3 Ethernet Port Replacement: 步骤 4 中的图像 2,2
    • Open the device by gently lifting the bottom half away from the top half of the device.
  5. Roku 3 Ethernet Port Replacement: 步骤 5 中的图像 1,1
    • Use your fingers to carefully lift the motherboard from the top half of the device.
  6. Roku 3 Ethernet Port Replacement: 步骤 6 中的图像 1,2 Roku 3 Ethernet Port Replacement: 步骤 6 中的图像 2,2
    • Pull away the IO shield from the motherboard using your hands.
  7. Roku 3 Ethernet Port Replacement, Ethernet Port: 步骤 7 中的图像 1,2 Roku 3 Ethernet Port Replacement, Ethernet Port: 步骤 7 中的图像 2,2
    • Turn over the motherboard so the back is face up and almost all large silver components are resting facedown on the table.
    • Orient it such that the backside of the HDMI port is in your upper right corner.
  8. Roku 3 Ethernet Port Replacement: 步骤 8 中的图像 1,1
    • Desolder all of the port's connections with a soldering iron.
    • For more information on soldering, check out iFixit's Soldering Guide.
  9. Roku 3 Ethernet Port Replacement: 步骤 9 中的图像 1,2 Roku 3 Ethernet Port Replacement: 步骤 9 中的图像 2,2
    • Locate the plastic push-throughs just to the left of the backside of the USB port.
    • Pinch the plastic push-throughs. The port should now be able to be removed.
结论
Andy Hak
于10/07/16注册
250 声望
创作了2篇指南
团队
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S15G2
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 1,601
