简介
This guide will demonstrate how to remove and replace the A/C power port. Be sure to check out the Soldering Technique Guide to learn ore about soldering before completing this repair.
你所需要的
Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
即将完成!
结论
