跳转到主内容
Roku 2 A/C Power Port Replacement
你所需要的
  1. Roku 2  A/C Power Port Replacement, Roku 2 Motherboard: 步骤 1 中的图像 1,1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2  A/C Power Port Replacement: 步骤 2 中的图像 1,1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2  A/C Power Port Replacement: 步骤 3 中的图像 1,1
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2  A/C Power Port Replacement: 步骤 4 中的图像 1,1
    • Gently remove the under side of the device.
  5. Roku 2  A/C Power Port Replacement: 步骤 5 中的图像 1,1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2  A/C Power Port Replacement: 步骤 6 中的图像 1,1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2  A/C Power Port Replacement: 步骤 7 中的图像 1,1
    • Remove the board from the plastic enclosure.
  8. Roku 2  A/C Power Port Replacement, A/C Power Port: 步骤 8 中的图像 1,1
    • Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
    • To learn more about soldering check out the Soldering Technique Guide.
  9. Roku 2  A/C Power Port Replacement: 步骤 9 中的图像 1,1
    • Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
结论
david quintana
于08/27/15注册
101 声望
撰写一个指南
团队
USF Tampa, Team 1-5, Sullivan Fall 2015 USF Tampa, Team 1-5, Sullivan Fall 2015 的会员
USFT-SULLIVAN-F15S1G5
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,318
