跳转到主内容
Ridgid R82005 Trigger Switch Replacement
你所需要的
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: 步骤 1 中的图像 1,1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: 步骤 2 中的图像 1,1
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: 步骤 3 中的图像 1,3 Ridgid R82005 Trigger Switch Replacement: 步骤 3 中的图像 2,3 Ridgid R82005 Trigger Switch Replacement: 步骤 3 中的图像 3,3
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: 步骤 4 中的图像 1,3 Ridgid R82005 Trigger Switch Replacement: 步骤 4 中的图像 2,3 Ridgid R82005 Trigger Switch Replacement: 步骤 4 中的图像 3,3
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
结论
2等其他人完成本指南。
Alex Cominos
于02/14/19注册
376 声望
创作了2篇指南
团队
USF Tampa, Team S1-G2, Leahy Spring 2019 USF Tampa, Team S1-G2, Leahy Spring 2019 的会员
USFT-LEAHY-S19S1G2
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 435
