跳转到主内容
Ridgid JobMax R2851 Series B Front Light Replacement
你所需要的
  1. Ridgid JobMax R2851 Series B Front Light Replacement, Front Light: 步骤 1 中的图像 1,2 Ridgid JobMax R2851 Series B Front Light Replacement, Front Light: 步骤 1 中的图像 2,2
    • Unplug the device from the wall.
    • Orient the device so that the trigger is facing downwards.
    • Place your thumb and index finger on the two buttons located on the head of the tool.
    • Press the two buttons in and pull the head of the tool off.
  2. Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 2 中的图像 1,1
    • Loosen all eight 15mm T10 Torx screws.
    • You do not need to fully remove the screws yet; just loosen them enough that the device shell starts to open.
  3. Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 3 中的图像 1,1
    • Orient the device so that the cord end is facing upwards.
    • Take a small cutting tool, and cut down the seam in the back, ensuring that you only cut the sticker.
    • Make a shallow cut to avoid damaging internal hardware.
  4. Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 4 中的图像 1,2 Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 4 中的图像 2,2
    • Completely remove all eight 15mm T10 Torx screws.
  5. Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 5 中的图像 1,3 Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 5 中的图像 2,3 Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 5 中的图像 3,3
    • Pull the device case off, gripping at the back of the case and rotating it towards the front of the device.
    • Once the device has been separated gently pull on the trigger assembly to remove it from one side of the case.
    • Watch out for the locking mechanism for the head of the device when removing.
  6. Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 6 中的图像 1,2 Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 6 中的图像 2,2
    • Once the device is apart, grab the LED light located in front of the trigger.
    • Slide the light upwards and out, freeing it from the device.
  7. Ridgid JobMax R2851 Series B Front Light Replacement: 步骤 7 中的图像 1,1
    • Once the light is free snip the wires and replace.
    • A soldering iron will be needed when installing a new LED.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 188
