跳转到主内容
Ridgid GEN5X R8642 Switch Replacement
你所需要的
  1. Ridgid GEN5X R8642 Switch Replacement, Switch: 步骤 1 中的图像 1,1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Switch Replacement: 步骤 3 中的图像 1,2 Ridgid GEN5X R8642 Switch Replacement: 步骤 3 中的图像 2,2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Switch Replacement: 步骤 4 中的图像 1,1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Switch Replacement: 步骤 5 中的图像 1,1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Switch Replacement: 步骤 6 中的图像 1,1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
  7. Ridgid GEN5X R8642 Switch Replacement: 步骤 7 中的图像 1,1
    • Remove the soldered connection from the switch assembly.
  8. Ridgid GEN5X R8642 Switch Replacement: 步骤 8 中的图像 1,1
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 301
