跳转到主内容
Ridgid GEN5X R8642 Battery Port Replacement
你所需要的
  1. Ridgid GEN5X R8642 Battery Port Replacement, Battery Port: 步骤 1 中的图像 1,1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Battery Port Replacement: 步骤 2 中的图像 1,1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Battery Port Replacement: 步骤 3 中的图像 1,3 Ridgid GEN5X R8642 Battery Port Replacement: 步骤 3 中的图像 2,3 Ridgid GEN5X R8642 Battery Port Replacement: 步骤 3 中的图像 3,3
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Battery Port Replacement: 步骤 4 中的图像 1,1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Battery Port Replacement: 步骤 5 中的图像 1,1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Battery Port Replacement: 步骤 6 中的图像 1,1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 369
