跳转到主内容
Revlon RVDR5061 Fan/Motor Assembly Replacement
你所需要的
  1. Revlon RVDR5061 Fan/Motor Assembly Replacement, Fan/Motor Assembly: 步骤 1 中的图像 1,1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Fan/Motor Assembly Replacement: 步骤 2 中的图像 1,1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Fan/Motor Assembly Replacement: 步骤 3 中的图像 1,1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Fan/Motor Assembly Replacement: 步骤 4 中的图像 1,3 Revlon RVDR5061 Fan/Motor Assembly Replacement: 步骤 4 中的图像 2,3 Revlon RVDR5061 Fan/Motor Assembly Replacement: 步骤 4 中的图像 3,3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
结论
Curtis
于07/11/18注册
159 声望
撰写一个指南
团队
IUPUI, Team S2-G2, Wilson Summer 2018 IUPUI, Team S2-G2, Wilson Summer 2018 的会员
IUPUI-WILSON-SU18S2G2
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,110
