跳转到主内容
Revise the Jura ENA Micro 9 drainage valve
你所需要的
  1. Revise the Jura ENA Micro 9 drainage valve, Jura ENA micro 9 opening procedure: 步骤 1 中的图像 1,1
    • Pull out the power plug!
    • Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
    • Remove all coffee beans.
  2. Revise the Jura ENA Micro 9 drainage valve, Top covers: 步骤 2 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve, Top covers: 步骤 2 中的图像 2,2
    • The top covers do not necessarily have to be removed for all repairs. However, it is indispensable for thorough cleaning. It may be easier to loosen the top covers if the side panels are removed first. The process is somewhat tricky.
    • Pry the central ventilation cover up.
  3. Revise the Jura ENA Micro 9 drainage valve: 步骤 3 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 3 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 3 中的图像 3,3
    • Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
    • If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
  4. Revise the Jura ENA Micro 9 drainage valve: 步骤 4 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve: 步骤 4 中的图像 2,2
    • Flip up the front cover.
    • Remove the cover. In the model with the side holes, you can pull them out at an angle to the front. With the other model, you have to push it back a little to unhook it, then lift it up.
  5. Revise the Jura ENA Micro 9 drainage valve: 步骤 5 中的图像 1,1
    • This is what it looks like when the two lids are gone. A lot of dirt built up.
  6. Revise the Jura ENA Micro 9 drainage valve, Side panels: 步骤 6 中的图像 1,1
    • The side parts are pushed out to the rear. However, they are secured with two screws and a lock at the top and a wedge-shaped catch on the sides.
    • Unscrew the two T15 Torx screws that secure the side panels at the top.
  7. Revise the Jura ENA Micro 9 drainage valve: 步骤 7 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 7 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 7 中的图像 3,3
    • The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
    • Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
    • Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
  8. Revise the Jura ENA Micro 9 drainage valve: 步骤 8 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 8 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 8 中的图像 3,3
    • This is what it looks like underneath. The lock is secured with an oval head screw. It looks like a rivet. To open you need a special oval head bit, in an emergency you can use pliers.
    • Remove the oval head screw.
    • Push the lock firmly upwards as far as possible.
  9. Revise the Jura ENA Micro 9 drainage valve: 步骤 9 中的图像 1,1
    • The side parts are held at the top and bottom with three hooks each. Therefore, they have to be moved backwards to detach them. However, they are secured against shifting with wedge-shaped notches at the front. The next step shows how they can be solved.
    • The notches must be lifted out of the openings. They are located on both sides at the top and bottom about 1.5 cm from the edge and 7 cm from the front edge.
    • This is what the wedge-shaped notches look like
  10. Revise the Jura ENA Micro 9 drainage valve: 步骤 10 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 10 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 10 中的图像 3,3
    • Lay the machine on its side.
    • Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
    • Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
    • Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
    • In the same way, insert another opening pick on the opposite edge.
    • Now both notches are free and the side part can be moved in the next step.
  11. Revise the Jura ENA Micro 9 drainage valve: 步骤 11 中的图像 1,1
    • Push the side panel firmly backwards. It may get stuck a bit and you need to use a plastic pry tool to help.
    • Take off the side panel and set it aside.
    • Repeat for the other side panel.
  12. Revise the Jura ENA Micro 9 drainage valve: 步骤 12 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 12 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 12 中的图像 3,3
    • Release the catches on the top of the inner cover.
    • Flip the inner cover down and lift it out. The brew group becomes now visible.
    • The cover is not present on all models.
    • The third picture shows a view of the other side.
  13. Revise the Jura ENA Micro 9 drainage valve, Dismantle the Jura ENA micro 9 brewing assembly: 步骤 13 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve, Dismantle the Jura ENA micro 9 brewing assembly: 步骤 13 中的图像 2,2
    • Peel off the silicone tube with a pair of tweezers.
    • Unscrew the Torx T20 machine screw in the middle on the left.
    • Access to the screw is obstructed by the filling funnel. A long shaft screwdriver will help.
    • Unscrew the Torx T20 machine screw in the middle on the right.
    • Unscrew the Torx T15 screw at the bottom right.
    • The brew assembly is now free. Gently tip it out at the bottom and remove it from the device.
    • When assembling, first insert the inlet nozzle at the bottom, then you can slide in the brew assembly
  14. Revise the Jura ENA Micro 9 drainage valve, Brew Assembly: 步骤 14 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve, Brew Assembly: 步骤 14 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve, Brew Assembly: 步骤 14 中的图像 3,3
    • The drive is on the left, the pulp shovel can be seen on the right.
    • Remove the two Torx T15 screws that hold the drive in place.
  15. Revise the Jura ENA Micro 9 drainage valve: 步骤 15 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve: 步骤 15 中的图像 2,2
    • Disengage the brown pulp shovel at the top.
    • Pull the pulp scoop down and out and set it aside.
  16. Revise the Jura ENA Micro 9 drainage valve: 步骤 16 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 16 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 16 中的图像 3,3
    • Remove the two Torx T20 machine screws that secure the drive to the upper piston.
    • Lift away the top cover with the coffee dispensing hose
    • Pull the metal retaining plate out of the upper piston. Note the orientation for later assembly. The top cover has a pin that must fit into the corresponding hole on the plate.
    • Turn the drive until it detaches itself from the brew assembly upwards
  17. Revise the Jura ENA Micro 9 drainage valve: 步骤 17 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 17 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 17 中的图像 3,3
    • In this step the two side covers are removed. They are each locked in four places, some of which are hidden.
    • Use your finger or a spudger to push the catches aside and lift the cover off.
    • Repeat for the cover on the other side.
  18. Revise the Jura ENA Micro 9 drainage valve: 步骤 18 中的图像 1,1
    • In this step, the two guide plates on the left and right are removed
    • There are two loose metal rings under the guide plates for guidance. Don't lose it.
    • Lift the two guide plates away. For later assembly, take a close look at how they are attached to the top of the piston.
  19. Revise the Jura ENA Micro 9 drainage valve: 步骤 19 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve: 步骤 19 中的图像 2,2
    • Slide the drainage valve down and out.
  20. Revise the Jura ENA Micro 9 drainage valve: 步骤 20 中的图像 1,1
    • Here you can see the current status
  21. Revise the Jura ENA Micro 9 drainage valve: 步骤 21 中的图像 1,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 21 中的图像 2,3 Revise the Jura ENA Micro 9 drainage valve: 步骤 21 中的图像 3,3
    • In the following step the lower piston is released.
    • The axis of the lower piston is secured with two ring cotter pins on the left and right. Use a sharp tool and pry out the two cotter pins.
    • Push out the axle.
    • Take a close look at the orientation of the piston, it will have to be reinstalled later. It has an indentation for the docking connector that has to fit.
    • Now you can turn the mechanics a little to the side and push out the piston. Further dismantling is possible, but not necessary. Make sure that there are two more metal rings at the top under the fork, these should stay in and not get lost.
  22. Revise the Jura ENA Micro 9 drainage valve: 步骤 22 中的图像 1,1
    • Unscrew the Phillips screw in the sieve of the lower piston and disassemble the piston.
  23. Revise the Jura ENA Micro 9 drainage valve: 步骤 23 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve: 步骤 23 中的图像 2,2
    • Unscrew the Phillips screw on the sieve of the upper piston and lift the sieve off.
    • Depress the catch on the side of the plunger and pull the crema valve up and out.
  24. Revise the Jura ENA Micro 9 drainage valve: 步骤 24 中的图像 1,1
    • The brew assembly is now dismantled. Now you have to clean all parts thoroughly, replace the seals on the upper and lower pistons, and thinly grease them and the cylinder wall with food-safe silicone. Now the drainage valve should also be revised.
  25. Revise the Jura ENA Micro 9 drainage valve, Drainage valve: 步骤 25 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve, Drainage valve: 步骤 25 中的图像 2,2
    • Remove the two T8 Torx screws securing the cover.
    • Use a plastic tool to pry the cover off and set it aside.
  26. Revise the Jura ENA Micro 9 drainage valve: 步骤 26 中的图像 1,1
    • Use a spatula to pull out the clip on the docking port. Don't lose the bracket.
  27. Revise the Jura ENA Micro 9 drainage valve: 步骤 27 中的图像 1,1
    • Release the water inlet from its catches and turn it up a little.
  28. Revise the Jura ENA Micro 9 drainage valve: 步骤 28 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve: 步骤 28 中的图像 2,2
    • Now carefully pry the valve body out of the carrier plate with a plastic tool. While doing this, push the white valve stem in so that it can slide out of its opening.
  29. Revise the Jura ENA Micro 9 drainage valve: 步骤 29 中的图像 1,1
    • Now you can completely dismantle the valve:
    • First pull the valve stem all the way out.
    • Pull off the water inlet.
    • Remove the docking nozzle from the carrier plate.
    • Pull off the two lids on the valve body.
    • Two seals are visible below. Get them out.
  30. Revise the Jura ENA Micro 9 drainage valve: 步骤 30 中的图像 1,2 Revise the Jura ENA Micro 9 drainage valve: 步骤 30 中的图像 2,2
    • However, there is still a third seal somewhat hidden in the valve body. First, pull out the plastic sleeve over it.
    • Then you can pull out the last seal, e.g. with a pair of tweezers.
  31. Revise the Jura ENA Micro 9 drainage valve: 步骤 31 中的图像 1,1
    • Now all parts have to be cleaned thoroughly.
    • Replace all of the seals and grease them with some food-safe silicone.
    • There are two seals on the docking nozzle, one thinner and one slightly thicker, as well as on the water inlet.
    • The direction of the lip seals is very important: the lips always point towards the pressure. The middle ring is inserted with the flat side first, then comes the plastic sleeve. The following ring faces out with the flat side. The ring on the other side also faces out with the flat side.
结论
6等其他人完成本指南。
由衷感谢以下译者:
de en
100%
oldturkey03正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
VauWeh
于10/19/15注册
292,988 声望
创作了303篇指南
1指南评论
Kompliment,
super tolle Anleitung
Vielen Dank
Ralph Ries - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 28
过去 30 天: 154
总计 7,734
