跳转到主内容
ResMed S9 VPAP Auto Knob Replacement
你所需要的
  1. ResMed S9 VPAP Auto Knob Replacement, Control Knob: 步骤 1 中的图像 1,2 ResMed S9 VPAP Auto Knob Replacement, Control Knob: 步骤 1 中的图像 2,2
    • Flip the device upside down.
    • Use a T3 Torx screwdriver to remove the screw in the corner.
    • Each screw in this guide is a 1.2mm Torx T3.
  2. ResMed S9 VPAP Auto Knob Replacement: 步骤 2 中的图像 1,2 ResMed S9 VPAP Auto Knob Replacement: 步骤 2 中的图像 2,2
    • Use a spudger to pry off the back panel.
  3. ResMed S9 VPAP Auto Knob Replacement: 步骤 3 中的图像 1,2 ResMed S9 VPAP Auto Knob Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to pry off the front panel.
    • If you are having difficulty, press the two hooks to open that side of the device.
    • Remove the front panel to expose the internal components.
  4. ResMed S9 VPAP Auto Knob Replacement: 步骤 4 中的图像 1,3 ResMed S9 VPAP Auto Knob Replacement: 步骤 4 中的图像 2,3 ResMed S9 VPAP Auto Knob Replacement: 步骤 4 中的图像 3,3
    • Remove the two screws on the circuit board with a T3 Torx screwdriver.
  5. ResMed S9 VPAP Auto Knob Replacement: 步骤 5 中的图像 1,2 ResMed S9 VPAP Auto Knob Replacement: 步骤 5 中的图像 2,2
    • Plug in and heat up the soldering iron.
  6. ResMed S9 VPAP Auto Knob Replacement: 步骤 6 中的图像 1,3 ResMed S9 VPAP Auto Knob Replacement: 步骤 6 中的图像 2,3 ResMed S9 VPAP Auto Knob Replacement: 步骤 6 中的图像 3,3
    • Locate the knob pins.
    • Desolder the solder pins on each side of the knob.
    • For more details on soldering best practices, check out our 如何焊接和拆焊 guide.
    • Be careful not to make contact with any of the other parts of the motherboard.
    • Remove the knob and replace it.
结论
2等其他人完成本指南。
4条评论
Do you have a source for the auto knob or a part number?
scott jensen - 回复
Do you have a source for this knob/switch or a part number?
scott jensen - 回复
You need a new rotary encoder, however the very popular and cheap EC11 does not work properly, you need a ddm 427 encoder, which is not very easy to find.
NG G. -
I found the right encoder from digikey. It has the wrong type of knob stem, but it works. It is the DDM 427.
Jim Burianek - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 689
