跳转到主内容
加入维修社区 - 创建账户
Replacing an Invisible Zipper
你所需要的
  1. Replacing an Invisible Zipper, Invisible Zipper: 步骤 1 中的图像 1,3 Replacing an Invisible Zipper, Invisible Zipper: 步骤 1 中的图像 2,3 Replacing an Invisible Zipper, Invisible Zipper: 步骤 1 中的图像 3,3
    • Prepare sewing machine with its compatible invisible zipper foot.
    • Thread the needle thread through the invisible zipper foot hole.
    • Pull the needle thread through the zipper foot hole.
  2. Replacing an Invisible Zipper: 步骤 2 中的图像 1,3 Replacing an Invisible Zipper: 步骤 2 中的图像 2,3 Replacing an Invisible Zipper: 步骤 2 中的图像 3,3
    • Locate the stitch lines of where the broken zipper was sewn on both sides of your garment.
    • Use a seam ripper to carefully rip out both of the stitching lines.
    • How to Rip a Seam
    • Make sure to not cut through the fabric.
    • Remove old invisible zipper.
  3. Replacing an Invisible Zipper: 步骤 3 中的图像 1,2 Replacing an Invisible Zipper: 步骤 3 中的图像 2,2
    • Turn the skirt inside out.
    • Place the replacement invisible zipper on the table, with the teeth side pointing up and the zipper pull facing down.
    • Unzip the invisible zipper. Line up the left side of the tape of the invisible zipper with the left side of your fabric.
    • The zipper teeth should 1/8" away from the edge of the fabric.
  4. Replacing an Invisible Zipper: 步骤 4 中的图像 1,2 Replacing an Invisible Zipper: 步骤 4 中的图像 2,2
    • Pin the tape of the zipper to your garment's fabric perpendicular to the invisible zipper.
  5. Replacing an Invisible Zipper: 步骤 5 中的图像 1,2 Replacing an Invisible Zipper: 步骤 5 中的图像 2,2
    • Place the teeth of the left side of the zipper into the right side of the invisible zipper foot.
    • When repeating on the opposite side of the zipper, place the teeth of the right side of the zipper on the left side of the invisible zipper foot.
  6. Replacing an Invisible Zipper: 步骤 6 中的图像 1,3 Replacing an Invisible Zipper: 步骤 6 中的图像 2,3 Replacing an Invisible Zipper: 步骤 6 中的图像 3,3
    • Sew a straight line carefully, removing pins as you go.
    • Repeat Steps 5-8 on the right side of your garment.
  7. Replacing an Invisible Zipper: 步骤 7 中的图像 1,3 Replacing an Invisible Zipper: 步骤 7 中的图像 2,3 Replacing an Invisible Zipper: 步骤 7 中的图像 3,3
    • Turn the skirt right-side out again, so you don't see the zipper teeth.
    • Rotate the fabric so the zipper foot is perpendicular to the zipper tape.
    • Position the zipper foot on top of the fabric 1/8th of an inch from where the zipper tape meets the garment.
    • Sew back and forth at least 6 times to seal the end.
    • This ensures that the zipper tab does not come off when you zip it up.
    • Flip garment over to see the stitch line you just made. Cut off excess zipper tape.
  8. Replacing an Invisible Zipper: 步骤 8 中的图像 1,3 Replacing an Invisible Zipper: 步骤 8 中的图像 2,3 Replacing an Invisible Zipper: 步骤 8 中的图像 3,3
    • Pull up your newly replaced zipper.
    • Be proud of yourself! You've just replaced an invisible zipper!
结论
另外一个人完成了本指南。
Katie Woo
于04/28/17注册
116 声望
撰写一个指南
团队
UC Davis, Team S3-G2, Coad Spring 2017 UC Davis, Team S3-G2, Coad Spring 2017 的会员
UCD-COAD-S17S3G2
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 26
过去 30 天: 105
总计 13,366
